Most noob question.
5 replies to this topic
  • Luv2brap-downunder
Posted May 22, 2015 - 02:12 AM
I can't find the link in the chain to break it. Pretty sure it's stock. D.I.D
520
  • claybilly17
Posted May 22, 2015 - 03:05 AM
Look on the tire side some times people put the on backwords
  • stevethe
Posted May 22, 2015 - 04:18 AM
520
The stock chains are rivet chains. Just buy a new Xring chain as the old one is a oring chain. You will also need a rivet installation tool.
  • Krannie McKranface
Posted May 22, 2015 - 04:42 AM
Grind two pins down flush with the plate
Using a Chain breaking tool, push the pin(s) until you can seaparate the chain
Installing the new chain, you will have to repeat this procedure to get the proper length
Use a master-clip type link to install the new chain
Posted May 23, 2015 - 04:58 AM
Will do, Cheers Steve
  • fixitandy
Posted May 23, 2015 - 06:44 AM
Hi Steve, & also I like to spooge a little Sikaflex over the master link clip, for added insurance, cheers Andy.
