Yz450 plastics help!?
4 replies to this topic
  • Zach Hanson
Posted May 21, 2015 - 05:42 AM
I have a 2003 yz450f and I want to put a newer looking front plate and front fender on it. Do any of you know if the bolt pattern for the 2013-15 front fender and number plate will match up? If you have a newer 450 withe the pointed fender and number plate can you post a pic of the bolt pattern and the back of the plate? Thanks!
  • 15thumper
Posted May 21, 2015 - 05:59 AM
You will have to drill a new hole maybe two for fender number plate probably not unless it bolts in same spot
The plate has one bolt into triple tree
  • Zach Hanson
Posted May 21, 2015 - 06:59 AM
Ok so the plate will fit. What's up with the fender? Is it 4 bolts?
  • 15thumper
Posted May 21, 2015 - 07:04 AM
Yes but two will be offline just take new fender put on old fender and drill new holes
Posted May 21, 2015 - 08:17 AM
UFO and a couple of other aftermarket plastics suppliers make the current design front fender/plate combos to retrofit the older bikes.
  • On January 15, 2017
  • 0 replies
