Decompression Bolt thread repair
4 replies to this topic
  • G-BRO
Posted May 14, 2015 - 08:27 PM
Well I think the last time I did a valve adjustment I botched the threads on the side bolt of the decompression system.
Now oil ever so slowly seeps down the side of the head, on to the header and down to the water pump area. Any thoughts on a simple fix? I would really like to avoid taking the head off. I have a new replacement bolt in hand, but I'm suspecting that the threads in the head are messed up.
I think Loctite makes an aluminum thread repair....
Oh and it's a 01 426
Edited by G-BRO, May 14, 2015 - 08:31 PM.
Posted May 15, 2015 - 06:40 AM
The bolt needs a copper washer; be sure it's there.  If the threads will hold 7 ft/lb (84 in/lb) they're OK.  It can be repaired by Heli-Coiling, but it's a PITA because of the need to break the drive tab off the coil.  A "Time-Sert" threaded insert is a better idea.
  • G-BRO
Posted May 15, 2015 - 08:42 AM
The washer is there. I have a replacement in hand to go with the new bolt. Would tapping the threads to the next size be a potential bad move?
Posted May 15, 2015 - 10:06 AM
Yes, because then you would need to make or have made a custom bolt for the hole, if you still have the manual decomp shaft in place.  the bolt has a cylindrical "nose" on it that runs in a groove in the shaft to retain it while allowing it to rotate.
  • G-BRO
Posted May 15, 2015 - 10:16 AM
I see your point. I'll see what I can do, thanks
Edited by G-BRO, May 15, 2015 - 10:20 AM.
  • Hot  30 replies
  • On January 15, 2017
  • Hot  113 replies
  • 5 replies
