08 wr450f clutch noise
9 replies to this topic
  • Luv2brap-downunder
Posted May 06, 2015 - 07:48 PM
I went to look at a 08yz450f
On idle with the clutch out, it made a rattle as soon as you put tension on the clutch ( start pulling it in ) it goes away. Is it just somthing with the adjustment or is a big problem
= a lemon
  • stevethe
Posted May 06, 2015 - 08:02 PM
Well they all make a different noise with the clutch out.
Posted May 06, 2015 - 08:23 PM
But a rattle ?
Not even riding the bike I noticed it when I had it on the stand
  • Krannie McKranface
Posted May 06, 2015 - 08:31 PM
Normal
They all make a horrendous racket, especially when just barely warmed up, with the clutch engaged.
Posted May 06, 2015 - 08:35 PM
I have been told the clutch basket could slightly worn ?
  • GuyGraham
Posted May 07, 2015 - 12:43 AM
Rattling with the clutch pulled in, is the plates against each other/basket, as they are in effect 'loose'  no problem this is normal
Rattling with the clutch engaged (but in neutral) is wear at the basket/primary driven gear interface. The gear is riveted to the basket. The manual says if it is loose replace basket , but in reality they are always loose after some use.
I wouldn't be too concerned unless is sounds like a bag of spanners being rattled
Edited by GuyGraham, May 07, 2015 - 12:45 AM.
Posted May 07, 2015 - 01:39 AM
Ok yeh
Guygraham it rattles with the clutch leaver out and sitting in neutral you can hear it just looking at the bike- can't tell if it is rattling when riding ofc
  • GuyGraham
Posted May 07, 2015 - 02:27 AM
It won't rattle when riding because it will be under load from the engine with the throttle open, or under load from the rear wheel with the throttle closed
Many many different types / makes / models of bike suffer clutch basket rattle when idling in neutral
My SV1000 does it
My old RD350YPVS did it
My WR450 2008 does it
Don't worry about it
  • stevethe
Posted May 07, 2015 - 04:00 AM
Hum every bike I own does it.
Posted May 07, 2015 - 04:32 AM
Oh thanks, guys &%$#@!en helped me out a lot! I just can't remember my yzf250 doing it.
