Seized engine...
1 reply to this topic
  • Ducky_Fresh
Posted February 17, 2004 - 01:30 PM
Not sure what to do. I seized the motor because I neglected the oil level. It gently bogged down after 1 session with the bike at Sears Point (this is a motard).
The only thing I know is that the kick starter won't budge at all. And it felt like I was running out of gas when the bike crapped out.
Anyone had this happen also? Maybe that way I'll know what the problem is before hand, I doubt it, but maybe..
I realize it'll prolly require at the least a rebuild of the top end and new piston/rings. At most a rebuilt motor.
Which is making me consider buying a WR450F motor and putting that in it's place. Anyone know how much those are going for? Or if they can directly bolt in?
THanks,
Everett
  • MrBlahh
Posted February 17, 2004 - 03:01 PM
Usually this type of failure wont damage the transmission, still enough oil to lube those parts.
Crank/rod, and the whole top end without a second thought would need an overhaul.
it's probably cheaper than a new engine, unless you find a deal on ebay.
