2014 or 2015 yz450f? Which to buy?
16 replies to this topic
  • yamie
Posted April 29, 2015 - 08:29 AM
Hey guys, I was looking for a similar topic but couldn't find one, so I hope I'm not making another similar thread.....
But I have a 2008 yz450f with lots of problems. So I'm going to keep it as a fix up bike and right now I'm going to buy a new bike. Here's the issue.....
Shopping around, the best deal I can find on a white 2015 yz450f is $9300 Canadian dollars. The same dealer has a brand new 2014 yz450f for $8100. Doing some research the bikes seem to be almost the same with the 2015 having just minor upgrades. For you guys who have experience or knowledge on this, is it worth spending the extra $1200 and picking up the 2015?
Posted April 29, 2015 - 08:45 AM
For $1200, yes, the '15 is worth it.  The difference should be bigger, though.  The price might be softer than you think on the '14, so you might try getting it down to say $7300. (CDN) I'd make that deal.  he actual differences between the two are pretty small, and the '14 is easy to update.
  • yamie
Posted April 29, 2015 - 09:47 AM
Thanks. Waiting for the dealer to call me back now, but he said that the best they could do would probably be $7900. Be a game time decision I think lol. Pretty excitied to get a bike that's EFI. So sick of trying to jet my old bike over and over :thumbsup:
  • MxSkater86
Posted May 01, 2015 - 07:18 AM
Buy the '14 and put the '15 front motor mounts on it. Thats $1200 you have in your pocket to put into extras for it.
  • GHILL28
Posted May 01, 2015 - 07:23 AM
If you're heavier, the '15 comes with heavier fork springs.  A re-map and swapping the $15 front motor mounts will take care of 90% of the rest of the changes.
  • jcm3
Posted May 01, 2015 - 08:18 AM
Are only the lower motor mounts different?  I checked Yamaha's site and the part numbers for the upper mounts are the same.
For the lowers, they are different part numbers.  They were two different part numbers for the lowers last year, but it looks like the 2015 uses just one part number which goes on both sides.
https://www.yamahapa...EL_-_2014/FRAME
  • MxSkater86
Posted May 01, 2015 - 08:20 AM
Yea it's just the lower ones. They are made of steel instead of aluminum
  • jcm3
Posted May 01, 2015 - 08:35 AM
Perfect, thanks for the clarification.
  • yamie
Posted May 02, 2015 - 05:56 PM
Ended up getting the 2014. it was a showroom bike that came with $1400 worth of extras, couldn't pass it up. Oh man is it ever fast compared to the 2008. Unreal!
Does anyone know if my 08 Rims will fit this 2014? I heard talks that they changed the rear axel in 2009.
  • Monk
Posted May 02, 2015 - 06:15 PM
Your 08 had 20mm front axle and 22mm rear axel. Your 14 has a 22mm/25mm axles. No, they will not fit...
  • yamie
Posted May 02, 2015 - 08:30 PM
 Thanks man! I was really hoping they would or I could buy spacers or something.
  • Monk
Posted May 02, 2015 - 08:35 PM
No. I wish you could though. I looked at bearings to fit but nothing common is made with that ID/OD.
  • yamie
Posted May 02, 2015 - 08:47 PM
Guess I have a set of rims going up for sale lol. How about the front forks? would you know if they would fit? Got a bit of money invested in those bad buys with race tech suspension inside, designed and revalved for my weight. I would just use them as a spare if possible
Edited by yamie, May 02, 2015 - 08:47 PM.
  • Monk
Posted May 02, 2015 - 08:50 PM
Maybe, only reason I would think there might be a issue is I think the newer forks are longer. You would have to get spacers too make the 22mm front hub work with the 20mm forks, or keep your old hub..
You might be able to transfer the inners into the newer forks. I did this with my 2012 KTM where I put 08 250sx inners that had been revalved.
  • philamoto
Posted May 07, 2015 - 10:39 AM
What does changing the motor mount brackets do? Do you do both to and bottom?
Posted May 07, 2015 - 10:59 AM
Read post #7.
The supposition is that the frame needed to be more flexible in that area, so steel was used to replace the older aluminum ones.
The bottom mounts are welded in place.
  • mikedabike
Posted May 10, 2015 - 05:57 AM
The fork will not work. The new fork has slimmer tubes at the top. They will not fit in the 14 triples.
  • Hot  113 replies
  • Hot  30 replies
  • Hot  50 replies
  • Hot  36 replies
  • Hot  47 replies
