Front rotor. I need schoolin'.
6 replies to this topic
  • wizbangdoodle
Posted April 27, 2015 - 07:00 AM
This is the front rotor on my 2012 wr450. Please tell me the purpose of having it separated from the hub.
When I was messing with my bike I noticed, when holding the front brake and rocking the bike, a little play.
When looking closer, it is from these floating rings that hold the rotor to the hub.
  • bikedude987
Posted April 27, 2015 - 07:21 AM
when the rotor heats up, it expands.  This allows the rotor to absorb more heat without warping.
  • wizbangdoodle
Posted April 27, 2015 - 08:16 AM
That makes sense. Why isn't the rear rotor the same? Not enough heat?
  • GuyGraham
Posted April 27, 2015 - 09:09 AM
Its called a 'floating' disc
as said above it allows expansion with warping
It also has side to side movement so you get better alignment with the caliper
Its more of a sports bike thing where braking from high speed can turn the discs blue (300°C +) - its a bit OTT on a dirt bike
  • Krannie McKranface
Posted April 27, 2015 - 12:46 PM
It's so when you tap the brakes lightly, you think your steering head is loose, and it drives you crazy until you realize they are floating discs.
  • wizbangdoodle
Posted April 27, 2015 - 03:10 PM
This is what I thought was happening at first. I thought my bearings were shot or something.
  • ThumpMe
Posted April 28, 2015 - 05:28 AM
 Been there done that....... and +1 on it driving you crazy!
