Wrf 450 water pump seal leak
4 replies to this topic
  • timceci
Posted April 24, 2015 - 07:29 PM
Hi, I'm after opinions on wether I should do a planned trail ride tomorrow (it's a tough one) as my 08 wrf 450 has just started dribbling from the little port under the water pump.....I'm happy to repair myself but parts are on order and will not be here by tomorrow!!
Should I ride my bike?? It dribbles a little when started from cold and seems to stop once warmed up, but could it let go altogether and over heat / seize the bike!!
  • matt71
Posted April 24, 2015 - 08:44 PM
All good . go ride and fix later .
  • GuyGraham
Posted April 24, 2015 - 11:18 PM
they will leak at start up and then stop when warm for quite a while
you are safe to go riding til you fix it
Mines been leaking all this year but I haven't got round to fixing it (again) yet, as it doesn't seem to like sitting over the winter
This is the third year in a row where its leaked after getting out from winter storage, but was fine when I put it away at the start of winter
  • timceci
Posted April 24, 2015 - 11:25 PM
Cheers Guy ,,, yep I wintered mine this yr so must be it.....will go & enjoy her thanks...
Posted April 29, 2015 - 02:36 PM
The seal can decide to leak any way it will, pretty much at will, so don't depend on its behavior staying the same.  If you ride it with this flaw, check the coolant level frequently.  There's barely two pints of it to begin with.
