Where did my brake pressure go?
6 replies to this topic
  • BlueBeast400
Posted April 24, 2015 - 04:33 PM
I reverse bled my rear brakes today and it basically has no pressure against the rotor now. I bled it again just to make sure all the air was out and still no pressure. They worked just fine before. Any suggestions?
  • patrick2wd
Posted April 24, 2015 - 10:37 PM
start again, topping up from the  top end working down,
if possible use a suction/ vacuum device to "suck" the oil out,
  • DonnieD
Posted April 26, 2015 - 04:15 PM
Not sure what reverse bleed is. But as mentioned those vacumns lime mtyvac work great. And if there is a rubber grommets in the reservoir, try taking that out.
  • BlueBeast400
Posted April 26, 2015 - 05:06 PM
Reverse bleeding is when you push the fluid through the caliper up to the reservoir. I used a syringe plunger and flushed out the old till new fluid filled up the reservoir. I flushed it again the traditional way from the reservoir down through the caliper. It is better now, but still not like it was. what does the rubber grommet do?
  • ThumpMe
Posted April 28, 2015 - 05:38 AM
I have had mixed results using a Mighty Vac suction gun. Sometimes I cannot get them to work on bike systems. Not sure why...think they are to powerful and sometimes pull the caliper cups back?
It sounds like there is a little "stuck" bubble of air somewhere in the system.
Take a small combination wrench or screw driver and tap lightly all along the caliper, line, and master cylinder to try and help break it loose.
Sometimes that works sometimes not.
Also I have found when reverse bleeding, especially on the older style FRONT lines that run down under the front caliper then up to the master I sometimes have to empty the line completely and then re-fill as if you get a bubble stuck in that lower section it is darn hard to push it back out. Starting over again when empty and pushing fluid up will usually clear it.
  • DonnieD
Posted April 28, 2015 - 01:01 PM
Good question that I don't have the answer to...and really can't remember if the WR has it since mine didn't give me any trouble. I used the Mityvac. my street bike has the grommet and costed me an hour of wasted time until I removed that rubber grommet. I like the Mityvac idea but that particular brand lacks in quality. Could have at least provided a case for all the pieces.
  • BlueBeast400
Posted April 28, 2015 - 07:34 PM
Mine does have the rubber grommet. So your saying it made it easier without the grommet?
