Need help from someone with good engine knowledge
6 replies to this topic
  • Adam842
Posted April 17, 2015 - 03:10 PM
I have a yz400f but am posting this here bc I want to know if anyone has had this happen to them even if they dont have a yamaha or no what my problem is.   The problem is my bike will foul the spark plug in a few minutes.  Its valves are all in spec, new piston and rings, new water pump shaft, and whole motor was just went through.  It will start up fine but has a little hesitation when you accelerate and then the spark plug fouls. Could the problem be a bad coil, spark plug cap or wire or what?  Any helpful advice is appreciated!
  • filterx
Posted April 17, 2015 - 03:28 PM
So every one of my post's tonite will have a google image search :)
Do you mean you are pulling the plug and looking at it after a few minutes?
https://www.google.c... plugs symptoms
Edited by filterx, April 17, 2015 - 03:29 PM.
  • Adam842
Posted April 17, 2015 - 03:56 PM
The plug fouls out but its dry not wet. Im thinking its something electrical related
  • Adam842
Posted April 17, 2015 - 03:57 PM
also when you rev it hard it will shoot out a black smoke sometimes but not always
Posted April 18, 2015 - 07:56 AM
Clean your air filter to start with.  That may explain the smoke.
Explain what happens, and why you think the plug is fouling.  Does the bike quit running?  What is the brand and heat range number of the spark plug?
  • Adam842
Posted April 18, 2015 - 08:12 PM
Like it will run rough in lower rpms and want to bog down but runs good in higher rpms. Also sometimes if i pull in the clutch it stalls but starts up fine. It will shut off even if im in the higher rpms to not just lower rpms.  I think its something electical and not jetting but dont know
Edited by Adam842, April 18, 2015 - 08:12 PM.
  • Adam842
Posted April 18, 2015 - 08:13 PM
Ill have to check on the spark plug
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  50 replies
  • Hot  47 replies
  • Hot  28 replies
