cam chain
6 replies to this topic
  • Hamish
Posted February 16, 2004 - 02:23 AM
As I have my bike apart for gearbox rebuild I wanted to check the cam chain. On other bikes I've owned, there has been a specified maximun length for 20 links of camchain.
Amyone know what it is for the WR?? The reason I suspect the chain is that when the engine is on TDC(according to the flywheel) the cam timing marks (inlet and exhaust) sit about 1/2 a tooth above the head surface. Maybe the TDC mark is incorrect, I'll check that with a piston stop and degree wheel on reassembly.
Hamish
  • thriller
Posted November 23, 2004 - 05:47 PM
I am wondering about cam chains as well. How do you know when they are bad?
  • Indy_WR450
Posted November 23, 2004 - 06:48 PM
punch marks dont line up when the chain is stretched from intake cam to exhaust cam when you check your valve clearances.
  • yz426onNOS
Posted November 23, 2004 - 09:41 PM
The cam chain should be good for the life of the bike. My dealer has never had one ordered or replaced one.
  • PowerFiend
Posted November 23, 2004 - 10:39 PM
Replacing the chain is cheap insurance. Better safe than sorry.
You can also tell how worn/stretched a chain is by how much travel is left in your cam chain tensioner. If your adjuster is maxed the chain can jump teeth, and that leads to bent valves, etc.
  • SteadyEddy
Posted November 24, 2004 - 12:48 AM
Hey hamish,
How many times have you had to rebuild that gerabox now :cry:
  • Hamish
Posted November 24, 2004 - 02:07 AM
Hey hamish,
Just the once, which was about 6 months ago.
Going to do the head soon as I managed to score a set of aftermarket Ti valves for pre release testing. I'll post the results when it's all done.
