Problem with front brake
4 replies to this topic
  • Smedes03crf450
Posted April 16, 2015 - 04:29 PM
So I took my front wheel off and accidentally pulled the lever so I opened the resivor so I could pry the pads together the when I got everything bolted up the front break is not working at all
  • TX-SANDMAN
Posted April 16, 2015 - 04:51 PM
time to bleed ... you an use the ol pump method or use a vacuum pump and pull fluid throught the bottom bleeder.  Habor Height has a Vacuum kit very cheap.
  • Muaythaicameron
it shouldn't matter. Keep pumping it up. The plungers could be stuck. Grab a pair of pliers and pull them out and in a few times
  • Muaythaicameron
Posted April 16, 2015 - 04:52 PM
why? As long as he didn't lose any fluid he shouldn't have to bleed since he just pushed fluid back into.the reservoir when he pushed the pads apart
  • Smedes03crf450
Posted April 16, 2015 - 05:18 PM
Okay yeah I didn't think I would need to bleed them like maybe I let air into the system but yeah I'll just keep pumping it is just thought it was weird
