Oil Leaking, help on changing seal
2 replies to this topic
  • JustG
Posted April 15, 2015 - 11:27 AM
Just ordered parts to replace seal, colar and o ring on the countershaft behind the sprocket. Shows the oring is behind the bearing. Is the bearing pressed in? I really don't want to split case. Please any insight on the subject matter...this will be my first attempt
Bike is an 09 wr450
Thank you
  • GuyGraham
Posted April 16, 2015 - 09:31 AM
The o-ring is on the ID of the collar
To change it
Take sprocket off
Lever out the Oil seal, by inserting a small screw driver between the OD of the seal and the recess in the cranckcase
Pull the collar off using small vice grips or similar
Fit the O-ring to the new collar and push it onto the shaft (use grease to aid assembly)
Fit the Oil seal (grease the lips of the seal, and the od of the seal to aid assembly)
Do not fit the oil seal then fit the collar as there is a risk of damaging the oil seal from the sharp edge on the collar as it goes in, and the new seal will leak
The bearing is fitted from the inside - if you need to change this then the cases need to be split
Edited by GuyGraham, April 16, 2015 - 09:32 AM.
  • JustG
Posted April 16, 2015 - 02:04 PM
Hm on the diagram we were looking at when I put in parts order, it showed the o ring behind the bearing....
Thank you for reply
