08 wr450 forks
5 replies to this topic
  • Yzfracer
Posted April 14, 2015 - 12:31 PM
Anyone buy  the  Factory connection revalve that includes modding the Base bolt? It's the more expensive revalve?? Comments? Worth 500 bucks?
  • stevethe
Posted April 14, 2015 - 12:41 PM
You have to fix or replace the base valves in the 08 WR forks or buy YZ forks in which they are replaced.
  • Yzfracer
Posted April 14, 2015 - 01:39 PM
Factory connection uses a updated base bolt which is used with the stock compression valve. more expensive than a regular revalve.
  • stevethe
Posted April 14, 2015 - 02:14 PM
You can't normally re valve a WR450 base valve. It uses a spring instead of shims. If factory connection is still using the spring in the old base valve say no thank you and go elsewhere.
  • Yzfracer
Posted April 14, 2015 - 09:31 PM
http://www.filterpub...log_usa_web.pdf
FACTORY CONNECTION 46/48MM BASE BOLTS
$179.95 a set
Designed to make your WR forks plush, progressive and have a smoother
action. FC Base Bolts and Revalving modifications are your answer
Page 14 in Factory connection catalog
  • stevethe
Posted April 14, 2015 - 10:11 PM
Well I'm not 100% sure they are talking about the the same thing as a base valve. They call it a base bolt. Read on http://www.thumperta...50-fork-valves/
