2009 wr450 oil in airbox
5 replies to this topic
  • Berrey775
Posted April 13, 2015 - 06:26 AM
Good morning,
New to this site and new as far as maintenance goes on my bike, 2009 wr450. Normally I take it to the dealer for service but I decided to change my own oil this time. I removed the drain pug and the dipstick to get the oil draining. not sure where the other bolt is. Here is what happened. the dealer says my bike takes 1 quart of oil. After draining the oil, (not sure if a whole quart came out) I put 1 quart of oil back in the engine. rode 55 miles. Noticed oil in the airbox after the ride, a lot. Is this from overfilling or do I have another problem?? any help would be greatly appreciated.
  • stevethe
Posted April 13, 2015 - 08:13 AM
Probably just over filled a bit.
  • 2009wr450
Posted April 13, 2015 - 08:22 AM
Periodic oil change 0.95L
With oil filter replacement 1.0L
Total amount 1.2L
One drain bolt on each side of the case.
Do yourself a favor and get a manual.
Over filling could cause damage.
  • Slow and Jerky
Posted April 14, 2015 - 03:58 AM
You should be able find the manual here:
There should be two drain plugs, one on each side off the engine, plus whatever comes out of the filter.
  • bobpara
Posted April 14, 2015 - 11:14 AM
Not sure how you are making the logical connection between one and the other. The oil may have been there for quite a while.
I'd wipe the airbox nice and clean and see if it comes back
If it comes back, then I'd dig a bit deeper
If not, you win
  • Krannie McKranface
Posted April 14, 2015 - 11:30 AM
Constant high rpms, or wheelies will dump oil in the airbox
