High idle
8 replies to this topic
  • springer8828
Posted April 10, 2015 - 04:52 PM
Hey guys 09 yz450f just picked it up only thing that I have noticed about is every now and then the idle will go up after I let off the throttle it will stay up for a few mins and then back down what could be the cause of this
Edited by springer8828, April 10, 2015 - 07:22 PM.
  • geedavell
Posted April 10, 2015 - 07:22 PM
Check the routing of the throttle cable.
Does it change RPM when you turn the handlebars to either side?
  • MotoAddict530
Posted April 10, 2015 - 08:37 PM
Air leak?
  • CDNSXV
Posted April 10, 2015 - 09:08 PM
Air Leak.  Or fuel screw needs adjusting.
  • springer8828
Posted April 11, 2015 - 04:59 AM
It doesn't do it when I turn. How is the best way to check for a air leak? I will check the fuel air screw to thanks guy's
  • MotoAddict530
Posted April 11, 2015 - 06:26 AM
Use carb clean or brake cleaner and spray the rubber boots and junctions around the card. Do this while the bike is running. If the idle spikes then you have a leak where you just sprayed. The same trick is used to look for leaky vacuum lines in cars and trucks.
  • springer8828
Posted April 11, 2015 - 07:49 AM
Oh alright cool thank you
Posted April 11, 2015 - 11:07 AM
Check your valve clearance. Right intakes can cause this.
  • springer8828
Posted April 11, 2015 - 02:08 PM
Alright will do
