wr 400 for short highwaay trips
8 replies to this topic
  • elrontx
Posted April 09, 2015 - 03:52 PM
whats up everybody, i have a plated 99 wr 400 with stock gearing. its mainly for offroad use but i was thinking of riding it on the highway to hit a small local spot where its not safe to park my truck. its about 7 miles each way, ill be cruising at apx 60. im worried about messing the engine up.  what do you WR experts on this fourm think? thanks.
  • JustG
Posted April 09, 2015 - 04:08 PM
Post your gearing and you'll get an answer. Most too lazy to look!
Edited by JustG, April 09, 2015 - 04:08 PM.
  • Jedmeister
Posted April 09, 2015 - 04:31 PM
Hey eltrontx,
I have a '98 WR400 that I recently rebuilt with 426 bits.  I run it in the bush once or twice a month, but it does most of its hours in motard trim with 17 inch rims.  I originally had 15/50 final gearing gearing on it but the revs were WAY to high for crusing the highway (awesome for blasting around below 80kmph though).  Went down to 15/44 next.  That brought revs at 100kmph (60mph) down to about 6600, but was still a bit high for my liking (a little vibey through the bars and pegs).  The engine in my bike is most happy between 5000 and 6000rpm so a further gearing drop to 15/39 has solved that issue.
I've put about 8000km on it on the pavement and about 1500km dirt, with a fair bit of that at pretty high revs with out issue (and oil changes every 500-1000km).
By the way, i did the rebuild because fourth gear lost a few teeth, the 400 cylinder/piston were in pretty reasonable condition when I replaced them.
If I were you I wouldn't hesitate to blast short trips at high revs.
Cheers, Jed
Also, check out gearingcommander.com to work out what revs your engine will be doing at your intended speed and make a decision from there.
  • elrontx
Posted April 09, 2015 - 05:11 PM
14/50
Edited by elrontx, April 09, 2015 - 05:20 PM.
  • elrontx
Posted April 09, 2015 - 05:13 PM
Hey eltrontx,
Cheers, Jed
thanks. im not to worried about it just want to hear other more mechanically inclined riders opinions. i change the oil every 200 miles or so. i ride mainly offroad.
Edited by elrontx, April 09, 2015 - 05:18 PM.
  • Krannie McKranface
Posted April 09, 2015 - 05:39 PM
14/50 at 60mph is not to bad
  • elrontx
Posted April 10, 2015 - 12:19 PM
thanks for the info guys.
  • bobpara
Posted April 14, 2015 - 11:26 AM
Just use your judgement and dont over-rev the thing
  • VinceDC
Posted April 15, 2015 - 05:16 PM
Your good, just don't shift it to hard on the road or you could have premature trans issues. They are not designed with a damper system like a street spec bike. So the trans can take a beating on the asphalt.
