Need help on Hour meter install
16 replies to this topic
  • Wr822
Posted April 07, 2015 - 07:54 AM
Hey guys, I'm trying to install an hour meter on my 09 and can't get it to register. Do I need to pull the spark plug boot up and wrap it around the boot under the rubber seal?
Posted April 07, 2015 - 09:00 AM
Yes.
  • Wr822
Posted April 07, 2015 - 09:08 AM
It will still seal correctly?
Posted April 07, 2015 - 09:09 AM
I doubt it.
  • Wr822
Posted April 07, 2015 - 10:46 AM
So I shouldn't do this or it's not a big deal, is that how yours is done?
  • SnowMule
Posted April 07, 2015 - 10:49 AM
:huh:
Wrap the lead around the plug wire a couple times
Feed the tail through the hour meter leaving enough room to mount it, clip it flush, and mount it up.  :excuseme:
  • nucular
Posted April 07, 2015 - 10:53 AM
Is the 09 different than the 08? On the 08, I wrapped it around the boot just above the seal.
  • Wr822
Posted April 07, 2015 - 11:05 AM
Snowmule, the problem is the plug wires on these bikes(and pretty much everything nowadays) don't look like that, they are just two 16g wires coming out
Nuclear, no difference in years as far as the plug wire goes, this worked for you?
Edit: I'm sorry thats probly a stupid question considering I doubt you would suggest that's what you did and tell me if it didn't work... Thanks!
Edited by Wr822, April 07, 2015 - 11:14 AM.
Posted April 07, 2015 - 11:08 AM
I don't use one.
  • Wr822
Posted April 07, 2015 - 11:15 AM
Since when gray?! When I did some searching, I seen you used to have one mounted in the airbox
  • nucular
Posted April 07, 2015 - 11:19 AM
Yeah mine works fine and i'm pretty sure that's how I rigged it. I'll double check tonight.
Posted April 07, 2015 - 11:22 AM
Nope.
  • Orvis309
Posted April 07, 2015 - 11:44 AM
Just buy a '10 or never, tuner can read hours...
  • eng208
Posted April 07, 2015 - 11:50 AM
Just wrap it 5 times around above the sseal then secure with a good tape. I use 33+ 3m. Works fine
  • SnowMule
Posted April 07, 2015 - 02:21 PM
Coil-on-plug?
The hour meter picks up from the high-voltage between the plug and coil.  As long as you've got a couple wraps between the two, it should work. :excuseme:
  • nucular
Posted April 07, 2015 - 02:31 PM
Coil-on-plug?
That's exactly how I did mine.
  • Wr822
Posted April 07, 2015 - 02:38 PM
Yep, just did it, works now! Thanks guys
  • 0 replies
  • Hot  50 replies
  • Hot  30 replies
  • Hot  113 replies
