How to I unclip the port for 2012 wr450f power tuner?
8 replies to this topic
  • hootie233
Posted April 04, 2015 - 03:42 PM
This is embarrsing, How do I go about unclipping the connector that you use to connect the GYTR power tuner into? It looks like there are 3 clips on it? I only have two hands and Im sure there is an easy obvious method that Im misssing out on. Thanks! Im new in case you cant tell
  • openbook215
Posted April 04, 2015 - 07:39 PM
  1. i hook my fingernail under the tab between the socket and plug
  2. pull tab away from plug and pull out plug
  • Nuklhed
Posted April 05, 2015 - 08:31 AM
Yea, second that.  It's way easier and the tab pulls to the outside, not push in.  If you can't get it with your fingers, you're doing something wrong.
  • 5270ADVRIDER
Posted April 05, 2015 - 09:04 AM
PULL the little tab, do NOT push.
  • Hooty
Posted April 05, 2015 - 11:20 PM
Yes
This is hilarious - I struggled for about 20 mins with that little clip ...
  • ApexAZ
Posted April 06, 2015 - 08:38 AM
This is kinda funny.  I struggled too.  Getting it off the mounting bracket was a challenge too.  I ended up taking the seat off so that I could fit a flathead into the clip release on the metal bracket.
  • hootie233
Posted April 06, 2015 - 07:51 PM
Thanks guys, I was definitely doing something wrong.... Before I start an extra thread does anyone notice that their idle adjustment knob doesnt do anything? Do how do I adjust idle?
  • 5270ADVRIDER
Posted April 11, 2015 - 08:54 AM
Mine works fine. Hook up a GYTR tuner, go to monitor mode and run the bike for actual readings. You can watch it change while making adjustments. I haven't tried to move mine drastically, but I've adjusted it with the meter hooked up so I know it works.
  • vlxjim
Posted April 11, 2015 - 09:33 AM
Make sure the knob is pushed in.
Oh and the plug is tight do to the water seal. But do lift the tab and pull.
