YZ400F Won't Start
3 replies to this topic
  • Peter S.
Posted April 03, 2015 - 11:29 PM
Hey all,
I have a 1999 yz400f that I took on a series of desert rides over the last week. All week the bike ran perfect, started in 1-3 kicks, and was a genuinely joyous bike to ride. Coolant always topped off, ran on non-ethanol 92 gasoline. Oil changed every 12 hrs. On the  last day of riding, I started the bike first kick when I unloaded it. It ran for around 10-20 seconds before I hit the kill switch. around 5 minutes later, I started it first kick again to warm it up. It ran for 5 seconds then died. It has not started since. Fuel was on, air filter clean, and I have tried kicking and bump-starting repeatedly. I have tried choke and hot start on, off and every combination of the two. Nothing. It will not start. Why is this? I suspect a fowled plug, although I have never had a 4-stroke do this before.  Bike makes good compression. Any thoughts? Thanks in advance.
  • springer8828
Posted April 04, 2015 - 05:57 AM
As funny as this may sound check your spark plug
Posted April 04, 2015 - 06:10 PM
With the older YZF models, the 400's and 426's that have a frame mounted coil and a plug wire, always start with a fresh plug.  The ignition isn't very strong at cranking RPM, so it doesn't take much to foul them.  It's wise to check to see if you have spark, of course.
  • Peter S.
Posted April 07, 2015 - 10:25 AM
Replaced the spark plug, Bike started second kick, smoked like crazy for 3 minutes, then ran exactly normal. Carb also overflowed gas for a few minutes, then functioned normally. Old plug was black and the gap was smaller due to the end being bent in.
  • On January 15, 2017
  • Hot  36 replies
  • Hot  50 replies
  • Hot  28 replies
  • Hot  30 replies
