Carb leaking...stuck float?
1 reply to this topic
  • BlueBeast400
Posted April 03, 2015 - 10:09 PM
I removed the carb off my wr400 and put in some new jets. When I installed it and turned on the gas fuel started dumping from the drain hoses. Can new jets cause this or is probably the float? Any suggestions on where to start?
  • Krannie McKranface
Posted April 04, 2015 - 05:19 AM
Where to start?
Pull the float bowl cover and look at it.... :facepalm:
You may have let the float pin slip out, or you might have a corroded float needle and cavity
