siezed rod bearing
  • 6 years later...
Wow, this is an old thread.
Anyways, the crank comes as a complete assembly or piece by piece. I just replaced my crank not long ago. We don't have any good machine shops close by to rebuild cranks, so it was easier to get the assembly.
Welcome to TT. ?
If you want to convert your YZ400F to a YZ426F this can be done using factory oem Yamaha parts. The YZ426F connecting rod uses a larger piston pin giving you a little better reliability.
Here's the parts needed to do the conversion:
(1EA) 5BE-11681-00-00 YZ400F CRANK PIN
(1EA) 93310-634B0-00 YZ426F CRANK BEARING
(1EA) 5JG-11651-00-00 YZ426F ROD, CONNECTING
(1EA) 5JG-11631-10-00 YZ426F PISTON (STD)
(1EA) 5JG-11603-00-00 YZ426F PISTON RING SET (S
(1EA) 5JG-11633-00-00 YZ426F PIN, PISTON
(2EA) 93420-19084-00 YZ426F CIRCLIP
(1EA) 5JG-11181-00-00 YZ426F GASKET, CYLINDER H
(1EA) 5BE-11351-00-00 YZ426F GASKET, CYLINDER
(1EA) 5JG-11311-00-00 YZ426F CYLINDER 1
