aluminum clutch cover
7 replies to this topic
  • SealClubber
Posted February 11, 2002 - 06:23 PM
Anyone know who sells aluminum clutch covers?
Dan
  • JBM
Posted February 12, 2002 - 05:29 AM
Try http://www.boyesen.c...utchcovers.html
Scratch that, it looks they only make them for the 2 strokes, but it may be worth checking into further.
[ February 12, 2002: Message edited by: JBM ]
  • dirtdad
Posted February 12, 2002 - 07:25 AM
why do you want an aluminum cover? Looks, weight savings? The stock cover is made out of magnesium so I don't think you'll save any weight.
  • enmerdeur
Posted February 12, 2002 - 07:46 AM
Procircuit has both clutch and ignition covers for the YZF's
Procircuit
  • SealClubber
Posted February 12, 2002 - 04:01 PM
I want aluminum because I can repair it if the hole is small. Also they are more durable. Magnesium is light and stiff but brittle and you cannot weld, pound, or grind it like aluminum. Carbon fiber is the same.
I had a small rock bounce off my boot, ding my cover and put a 1/4 inch crack in it. If it were aluminum I could fix it.
www.brpit.com sells them for $90. They aren't listed on the websight. You have to call them.
1-800-834-9363 :)
Procircuit only sells Magnesium. Thanks though.
Dan
[ February 12, 2002: Message edited by: Dan Lawrence ]
  • enmerdeur
Posted February 13, 2002 - 11:24 AM
I fixed the small hole in my ignition cover with JB Weld. Two years later it is still holding!
  • SealClubber
Posted February 13, 2002 - 06:56 PM
I was told JB weld is porous so I don't think it would work on the clutch cover, but if I ever crack my ignition cover I will certainly try that.
Thanks,
Dan :)
  • enmerdeur
Posted February 13, 2002 - 08:44 PM
It really doesn't matter which side since both sides have oil to contain (on the YZF that is). The JB Weld has kept the oil in without a problem. All this is somewhat moot since you would rather have something you can weld and luckily you have found it. I would be interested in seeing photos of the aluminum cover when you get it. Post some if you can.
  • Hot  30 replies
  • Hot  47 replies
  • Hot  50 replies
  • 10 replies
  • On January 15, 2017
