wr400f carb - stripped float bowl threads
3 replies to this topic
  • BlueBeast400
Posted March 27, 2015 - 02:00 PM
Today I was re-jetting my carb and noticed one of the corner crews of the float bowl backed out way to easy. The screw is fine, but the threads on the carb side are stripped out. Should I just get a longer screw and and put a nut on the other side or drill and tap to a larger size? what would be best?
  • JVP
Posted March 27, 2015 - 02:05 PM
If you can use a longer screw and use a bolt.  There is not a lot of room for error if you tap a bigger bolt.
  • stainless601
Posted March 27, 2015 - 02:39 PM
I've got a carb off 2006 WR 450. Runs out strong, Boyesen quick shot acell pump, all cables ready to go, PM me if you need it.
  • BlueBeast400
Posted March 27, 2015 - 02:41 PM
Ya, that's what I was thinking. If I drill a bigger hole and screw up the tap, then I'm really screwed!
