AC lighting question
Yamaha WR426F
4 replies to this topic
  • jwoue92
Posted March 27, 2015 - 08:38 AM
Hi Everyone,
I'm converting my yz426f for the street, doing the WR stator/flywheel swap. I want to keep it simple so I was planning on keeping the AC circuit. I've heard that AC will not run the flasher unit for the blinkers. I thought this would only be true if I was running LEDs, which I am not.
Will the AC system run the blinkers?  I appreciate the help.  -Jeff
Posted March 27, 2015 - 09:05 AM
I don't know about blinkers, but you can add a rectifier/regulator to create a DC sub circuit.  Remember to keep either the AC or DC side off of the chassis ground.
BTW, LED's will run on AC, but they'll flicker at low cyclic frequencies.  They're on when forward biased, off when reversed.
  • jwoue92
Posted March 27, 2015 - 12:21 PM
I wanted to stay away from having a battery and stick with AC current. But if I still need DC to run the turn signal flasher and horn, do I need to float the ground on the stator too?
Or can I just ground the pink wire from the six point connector to use my YZ cdi and just use a rectifier to get DC?  Still trying to fully understand this, thanks again for any help.
Edited by jwoue92, March 27, 2015 - 12:21 PM.
  • jwoue92
Posted March 27, 2015 - 02:45 PM
So if the tail light is LED and I'm running AC, do you think it'll flicker at idle?
Posted March 27, 2015 - 02:51 PM
It might, but I doubt it.  If you plug an LED into a wall socket, which cycles at 60Hz, you can "sort of" detect a flicker.  At 1500 RPM, your AC system should cycle a bit more than 75Hz, unless I'm missing something.
If you are using the YZF CDI, I believe you will NEED to float the ground on the stator.
Legal WR426 Worth it? by supertaco
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • 4 replies
Wheel Interchange: What fits what? by grayracer513
  • Hot  144 replies
Post Your WR426 Project! by aj1208
  • 13 replies
YZ426 Stator Mod HELP by blueshortridge
  • 4 replies
best looking 426 anyone by buzzgrizz
  • Hot  238 replies
