Replacing main jet on a 01 426
3 replies to this topic
  • 426scooby
Posted February 11, 2002 - 03:52 PM
New to the motorcycle world, looking for some help on how to change the main jet on a 01 426.
I have the owners manual but is no real help to a novice. Thanks for the Help!!!
  • Wyatt
Posted February 11, 2002 - 04:04 PM
You need a 17mm socket and a 6mm socket. First, drain the carb bowl with the drain screw. (allen head) Remove the large plug on the bottom of the carb bowl. You will be able to see the tip of the main jet if you look into the hole. Use the 6mm to take it out. You can do it in less than two minutes.
  • MN_Kevin
Posted February 11, 2002 - 04:10 PM
Turn off your fuel at the petcock and run your engine until you suck the carb dry.
what he said above!! :D
WARNING :D WARNING :) WARNING :D
You WILL have gasoline EVERWHERE unless you turn your petcock off and run your carb dry of fuel.
[ February 11, 2002: Message edited by: NH Kevin ]
  • Boit
Posted February 12, 2002 - 03:11 PM
Ditto on the above advice. Also, if you use one of those small mechanic's mirrors, you can see up into the bottom of the carb and locate the main jet and pilot jet. When installing a main jet, don't over tighten. It's only brass so it will strip easily. Just snug and then a little more will suffice. Be gentle.
  • Hot  36 replies
  • Hot  47 replies
  • Hot  38 replies
  • 0 replies
