Exhuast is melting air filter box
57 replies to this topic
  • RPS444
Posted April 01, 2015 - 11:37 AM
#21
We checked the carb boots for leaks and nothing there. I'll try again to see if there's any leaks though. When you say hot start how do you check for a leak with it? The kid that owned it before me cut the air filter box down in the back. Would that cause the problem?
  • 03yzf450-kuke
Posted April 01, 2015 - 12:56 PM
#22
Well first of all when its running try pulling the hot start lever and see if it changes rpms
  • 03yzf450-kuke
Posted April 01, 2015 - 12:59 PM
#23
As for plugging it remove hot start fitting from carb.chech the o ring on the plunger and also try plugging the air passage and then run it to see if pipe still gets hot that fast. I have to say don't dump off the bike keep looking for what is causing it to run lean you will eventually figure it out
Posted April 01, 2015 - 01:02 PM
#24
The hot start air passage is entirely internal to the carb.  How exactly do you propose to plug it?
  • 03yzf450-kuke
Posted April 01, 2015 - 01:09 PM
#25
Well I'm no rocket scientist but I could figure out you need to use something as a plunger
  • 03yzf450-kuke
Posted April 01, 2015 - 01:12 PM
#26
Its pretty simple to replicate a plunger
Posted April 01, 2015 - 02:43 PM
#27
The best thing to use is an actual plunger with a good seal on it.  Don't complicate simple things.
  • 03yzf450-kuke
Posted April 01, 2015 - 05:24 PM
#28
Ya I guess you are right. Electrical tape on a screwdriver is getting a bit too complicated...
  • RPS444
Posted April 02, 2015 - 04:49 AM
#29
I have ordered all new seals for the water pump and hot start. I'm also welding a small crack on the mid pipe where it connects to the muffler and repacking the muffler to see if that helps. Thanks everyone for all the great help!
  • 03yzf450-kuke
Posted April 02, 2015 - 05:06 AM
#30
Keep us updated
  • RPS444
Posted April 13, 2015 - 06:52 AM
#31
So we replaced the water pump rings and the hot start seal. We tested the hot start and it seems to work fine. We started the bike and when I pull the hot start it drops rpm's significantly. It definitely helped to keep the bike from running so hot but unless I'm riding it, the mid pipe still seems to be getting very hot, almost red hot. The dealer told me they run hot so is that just how they are? What is the difference in the Yamaha trail bikes that keep them from running so hot?
  • 03yzf450-kuke
Posted April 13, 2015 - 02:47 PM
#32
They do run hot and it is normal for header to glow after idling for a couple minutes but the mid pipe definitely should not glow red.
  • 03yzf450-kuke
Posted April 13, 2015 - 02:48 PM
#33
Have you checked the spark plug after letting it idle and the midpipe gets hot to see what the Afr is like
Posted April 13, 2015 - 02:56 PM
#34
The spark plug won't tell you that.
  • 03yzf450-kuke
Posted April 13, 2015 - 05:59 PM
#35
Lean or rich
Posted April 13, 2015 - 07:04 PM
#36
Nope.
  • 03yzf450-kuke
Posted April 14, 2015 - 02:28 AM
#37
Wat do you mean?
  • 03yzf450-kuke
Posted April 14, 2015 - 04:14 AM
#38
Does plug check not work on idle? Explain
  • RPS444
Posted April 14, 2015 - 05:02 AM
#39
Spark plug is fine but it's still idling high. I have heard you can adjust the pilot by lowering or raising a couple notches. Is that worth a try?
  • 03yzf450-kuke
Posted April 14, 2015 - 05:15 AM
#40
Look up on here how to jet pilot circuit.... The clip positions I assume you are talking about are on the needle and the needle generally affects 1/8 to 7/8 throttle, not idle.
  • Hot  38 replies
  • Hot  113 replies
  • Hot  47 replies
  • Hot  30 replies
