08 WR 450 Forks
9 replies to this topic
  • Rodneya
Posted March 21, 2015 - 07:30 AM
What forks came on the 08 wr 450. Are they SSS?
  • stevethe
Posted March 21, 2015 - 08:53 AM
Absolutely positively not. They have what I call a defective base valve in the bottom of the forks. You need to install a valve that uses shims instead of a spring. Racetech makes a gold valve that gets rid of the useless stock base valve spring system.
  • Rodneya
Posted March 21, 2015 - 09:54 AM
thanks
  • RMK800
Posted March 21, 2015 - 01:41 PM
Just buy 2006 YZ 450 SSS forks then sell your current ones. You'll be out 200.00 to 300.00 which is a lot better then stock with custom valves at 200. It's a no brainer! Best mod I have done.
  • Krannie McKranface
Posted March 21, 2015 - 06:12 PM
Absolutely positively, unequivically no f'ing way not.  They have what I call a defective base valve in the bottom of the forks. You need to install a valve that uses shims instead of a spring. Racetech makes a gold valve that gets rid of the useless stock base valve spring system.
^^ do that and live.
  • KennyMc
Posted March 26, 2015 - 09:13 PM
Bought the '06 YZ forks for $300, sold my stock ones for $150. Then had them revalved by ENZO, sweetness ;)
Then sold the bike a few years later :D
  • Derwud
Posted March 27, 2015 - 12:18 PM
What year forks swap over with the least trouble??
  • KennyMc
Posted March 28, 2015 - 09:09 PM
For the '07 and up before the big change, the '06 YZ forks bolt right up with nothing else to do. You get to keep the ODO.
Posted March 29, 2015 - 07:22 AM
2006 only, 250/450 YZ only
Previous years are AOS models (suck)
Later years have different caliper brackets
  • Derwud
Posted March 29, 2015 - 07:23 AM
Thanks Bill and Kenny.
