22mm Offset Triples
5 replies to this topic
  • SBK
Posted February 13, 2004 - 07:02 AM
Anybody have any first-hand experience with the BRP offset triples? 2mm offset change can make a significant impact on handling, as I've experienced with some streetbike stuff. I've seen the Off-Road.com write-up, etc. Just wondering if anybody here has tried them and can offer a first-hand account and assessment on whether they'd do it again after living with them for a while.
  • SBK
Posted August 09, 2004 - 07:35 AM
Just bumping this one back up to the top to see if anyone's tried the BRP or Dirt Tricks offset clamps on their WR.
  • ncmountainman
Posted August 09, 2004 - 08:53 AM
i dropped the clamps 1/4" from even at the top of the forks and the change was dramatic if it turned any faster i would have put it back! try that first if you havn't, its free! :thumbsup:
  • ckulzer
Posted August 09, 2004 - 12:11 PM
Pulling up the forks affects ride height too. I pulled mine up 6mm but I don’t like the effect it has on rear traction.
Finding a ride height/weight distribution balance is an ongoing challenge when flat tracking. Although I am not flat tracking my WR, the same theory applies.
I am thinking about changing the offset to reduce trail and quicken steering without effecting ride height.
Let’s get back to the original question….Has anyone changed the offset with a different triple clamp? What about YZ parts? Is there a YZ250 bottom clamp that is different than a stock WR clamp?
Ride fast - take chances
  • yimmyhauler
Posted August 09, 2004 - 05:46 PM
I have the Scotts ... They were mainly purchased for the Virginia woods (VCHSS). They make the bike definitely more manageable in tight woods.
  • SBK
Posted August 10, 2004 - 12:45 AM
Cool, thanks for the post. When you say "makes the woods more manageable" - what exactly do you mean? Less offset on a smooth-tired bike generally results in more front end feel and a bike that seems to track better. Would you describe the 22mm offset in a similar way? This kind of stuff is always hard, putting a change in "feel" into words. Thanks for any more descriptive info you can provide on the change you saw when moving to the 22mm offset.
