bit of rust in carb
13 replies to this topic
  • YamahaRideOne
Posted March 18, 2015 - 07:29 PM
Hey guys, so far i have found somewhat of my problem on my 06 WR450F is, but when i was in the carb i found a little bit of rust in the AP i had to guy a new rubber piece as it was all rusted, but there is a little rust on the inside still... the carb cleaner took off most of it but there is still a little there. should i be concerned with this ? if so what do you recommend using?
Thanks
  • Krannie McKranface
Posted March 18, 2015 - 07:59 PM
You want to remove all corrosion
Use Pine sol, stiff fishing line for the passages, and spray cleaner like brake cleaner ( or strong compressed air)
The accelerator pump has a check ball inside the float bowl cover that needs to move freely, and usually is shot if you see any rust in the bowl
That's when you upgrade to the 2008 Honda specs.
Search accelerator pump upgrade
  • YamahaRideOne
Posted March 18, 2015 - 08:13 PM
Your talking the AP cover? The part that comes off when you unscrew it? Is so that part was all clean and when i soacked it in carb cleaner i had no blockage in the holes. All the holes allowed carb cleaner to spray outof another hole.
  • YamahaRideOne
Posted March 18, 2015 - 08:15 PM
Also its not in the bowl it was around the metal piece on the diaphragm
  • ThumpMe
Posted March 19, 2015 - 06:18 AM
Those steel pieces on the diaphragm due tend to get rusty. Clean it off best you can. I have also found you can get this stuff called Evaporust off the internet or sometimes Home Depot carries it. It works WONDERS for removing rust. Do not think it will hurt rubber but just to be sure apply it with a q-tip if using it, and then be sure to wash it all off once done.
  • YamahaRideOne
Posted March 19, 2015 - 07:36 AM
I already ordered the diaphragm. It was bad. The carb itself only has a little spot. But the diaphragm was stuffed with sand and dirt. There is this stuff called metal rescue it seems like it could do exactly what i want.
  • YamahaRideOne
Posted March 19, 2015 - 07:38 AM
Ah yeah. Same kinda stuff as metal rescue
  • JMundy
Posted March 19, 2015 - 03:33 PM
what diaphram did you order.  I would HIGHLY recommend you follow Kah Ran Nee's advice and do the crfsonly.com acc pump upgrade.  World of difference on my 07 WR450
  • toten
Posted March 19, 2015 - 04:55 PM
http://www.crfsonly....roducts_id/3932is that the upgrade you're talking about?
  • JMundy
Posted March 19, 2015 - 04:57 PM
Yep! Get a stiffer acc pump linkage spring. I got mine from tokyomods.com
  • YamahaRideOne
Posted March 19, 2015 - 05:11 PM
i ordered a new stock one. im not to worried about any upgrades until i get it running again..... it did run before i failed to do maintenance due to be being new to bikes when i got it. and it was beastly when it ran no problems there. i'm not concerned with the diaphragm i'm more wondering about the small rust spot on the carb itself.
  • ThumpMe
Posted March 19, 2015 - 07:53 PM
Is it just a discoloration on the carb? Rust can sometimes stain stuff and it is a bear to get the stain removed, but usually it will not affect anything, just looks ugly.
  • YamahaRideOne
Posted March 20, 2015 - 06:43 AM
it could just be a stain, stuff came off with the carb cleaner, its just a small spot that i couldn't seem to get off. but now that i think about it it was just color. the diaphragm was the part that actually had rust on it. was brown and white.
Posted March 20, 2015 - 06:13 PM
Nothing to worry about
The CHECK BALL in the bowl cover, is probably corroded to, so free it up, or so the upgrade like I mentioned.
