2012 Engine Braking
9 replies to this topic
  • cm517chris
Posted March 18, 2015 - 05:17 AM
My wr450f has some pretty serious engine braking down in the low gears. Do the motocross 450's have the same engine braking? Are you able to change this without taking off the head? I've used different maps but doesn't effect it under 3k I 'believe'.
  • ThumpMe
Posted March 18, 2015 - 05:26 AM
Not really, this is just how a high compression four stroke motor works.
If you ride a two stroke after having been riding a four stroke it will amaze you as the two strokes have almost NO engine braking.
  • Krannie McKranface
Posted March 18, 2015 - 05:28 AM
Shift up.
Don't use the motor as a brake.
Stay in the higher gear, and use the clutch to modulate your way to acceleration.
This gives you the best of all worlds: controlled traction and no engine braking.
  • cm517chris
Posted March 18, 2015 - 06:35 AM
Nice! Thanks for those. Yes world's different from my cr125 lol obviously.
  • stevethe
Posted March 18, 2015 - 07:00 AM
Wow thats a big jump in bikes and yes you'll notice a lot of compression braking from one to the other. Over time you may enjoy that compression braking. You just have to use higher gears as mentioned and get used to it.
  • patrick2wd
Posted March 18, 2015 - 07:41 AM
you could help the engine a bit by altering the ignition/ injection setting with the blabla (keep forgetting) gytr blabla thing..
Im not sure this is a good answer.. :facepalm:
  • ThumpMe
Posted March 18, 2015 - 08:17 AM
Yeah I am not sure THAT was good answer either but it sure was funny!
  • patrick2wd
Posted March 18, 2015 - 08:28 AM
I hope everyone knows what I mean............................ :cry:
  • vlxjim
Posted March 18, 2015 - 08:46 AM
The best was the lessen the engine braking on a four stroke is to stay on the gas.  :lol:
  • MidlifeCrisisGuy
Posted June 15, 2015 - 11:42 PM
A YZ exhaust cam decreases it significantly.   Makes the on/off transition much smoother and increases low end torque and throttle response too.
