Yz450f rebuild help
26 replies to this topic
  • 03yzf450-kuke
Posted March 19, 2015 - 01:39 PM
#21
Well no I drained the oil and coolant before removing the cc cover so that couldn't be it
Posted March 19, 2015 - 02:22 PM
#22
You're not following.  The leak that caused your oil to get contaminated was at the crankcase cover gasket and O-ring, not the water pump.
  • 03yzf450-kuke
Posted March 19, 2015 - 03:35 PM
#23
I don't understand. Why do you suggest those seals were leaking? I didn't even replace those seals just the impeller seals and it fixed my problem
Posted March 20, 2015 - 06:26 AM
#24
You had the right cover off to replace the shaft seals.  You put it back together with the old gasket and O-ring?
  • 03yzf450-kuke
Posted March 20, 2015 - 08:31 AM
#25
Yes that is correct. But I found the coolant in my oil when I drained oil before taking cover off.I know its frowned on to re use gaskets but I did any way and no leaks
  • ghorn0103
Posted April 07, 2015 - 05:11 PM
#26
Turns out it was one of the dowl pin o-rings between the right crank case cover and case or the one between the cylinder and crank case. Wasnt sure which so i replaced both o-rings and dowell pins. Completely solved my issue. Thank yall for all the help!
  • 03yzf450-kuke
Posted April 08, 2015 - 02:34 AM
#27
Ride on brotha
  • 0 replies
  • Hot  30 replies
  • Hot  50 replies
  • Hot  113 replies
