Electric fan?
11 replies to this topic
  • YFZ439
Posted February 12, 2004 - 05:29 PM
I'm making a street supermoto with a 2004 WR450 and was a little worried if stuck in traffic for any length of time about it over heating? Has anyone ever put on a electric fan. I see KTM has a nice kit for their bikes, wonder if it would work for the WR as well? Thanks for any advice
  • ddialogue
Posted February 12, 2004 - 06:08 PM
Do you have a link for the KTM fan kit? I'd be interested in taking a look at it. I'd like to have one when I ride the dunes.
  • BEAN329
Posted February 12, 2004 - 06:10 PM
2 things, a computer case fan should have the proper voltage + or - 12v DC, but getting dirt or mud inside may be a problem. You may want to inspect KTM's offering and adapt it. I think it's a great idea even better if you can put a temp sensor somewhere in the cooling system.
  • gfergtr74
Posted February 12, 2004 - 09:18 PM
The KTM fan will work. I sold one to a gentleman with an 03 450 for the same reason. It a little modification to fit but all in all worked well. Be warned it is not cheap. The computer fans as mentioned above will work as well and are less money by far. I think personally I would try the computer fan first and set it in a few different locations to see what worked best.
  • ddialogue
Posted February 13, 2004 - 05:07 AM
Are we talking $100? $200? :)
  • Eddie Sisneros
Posted February 13, 2004 - 05:12 AM
computer fan.radio shack.$20.lots of drz guys have been running htme for many many miles.no problems.
  • ddialogue
Posted February 13, 2004 - 05:37 AM
What about water resistance? I wouldn't think a computer fan would be designed to resist water.... :)
  • Eddie Sisneros
Posted February 13, 2004 - 06:10 AM
they seem to hold up fine.
  • captain_S
Posted February 13, 2004 - 12:13 PM
Try a fan from a trials bike(never knew a computer fan would run on 12v)but always knew they were the perfect size for the job!
  • gfergtr74
Posted February 13, 2004 - 01:07 PM
I can't remember for sure but the 150-200 mark seems right.
  • YFZ439
Posted February 13, 2004 - 02:20 PM
The fan kit is in the KTM parts book and it is thermostatically controled. I was quoted $100 for the kit from the dealer.
Thanks for the tips, i'm probably going to try the KTM kit :)
  • BEAN329
Posted February 13, 2004 - 04:38 PM
$100 beats overheating if needed. One other thing about overheating check the clearance between the header pipe and the water pump housing. After a couple of crashes mine is very close.
