shift shaft removal
5 replies to this topic
  • Stayinthirsty
Posted March 11, 2015 - 03:41 PM
Bike is an 10 yz450f. Previous owner bent the crap out of the shift shaft. I'm having trouble getting it out to replace it. It slides very easy for a 1/2 inch then it hits considerable resistance I assume this is where the bend is. Anyone have any tips or tricks to try getting it out?
  • zotis777
Posted March 11, 2015 - 03:54 PM
Pull it until it stops, then I would (idk if it's the best idea, but best I can think of)
Use this method to bend it back enough to pull it out
  • Stayinthirsty
Posted March 11, 2015 - 07:17 PM
Went out and gave that idea a whirl. I think the only way it would work is with heat. I couldn't get the shaft to budge. That shaft is damn stout for being so small in diameter. Great idea and gives a lot of leverage. Thanks for the response.
  • zotis777
Posted March 12, 2015 - 04:39 AM
Do you have a new one? Cut the old one
Posted March 12, 2015 - 07:07 AM
Cut the old shaft off.  It won't be easy unless you use a high speed abrasive cut-off wheel at 15K RPM or so.  You can either cut off the lever end on the left, or push it to the right as far as possible and cut the internal lever off the right end of the shaft and take it out the other way.
  • Stayinthirsty
Posted March 14, 2015 - 12:52 AM
Thanks, I was just about to ask if it would slide out the other way since I can't get to the bend from the left. Time to bust the Dremel out.
  • On January 15, 2017
  • Hot  38 replies
  • 0 replies
