Yz450f shifting problems.
9 replies to this topic
  • lferrell22
Posted March 09, 2015 - 06:18 AM
I have a 2009 yz450f and I was riding it home very gently when the chain broke and it flipped over and hit my foot and my shifter. Now my bike will only go in first and second gear but if you fiddle with the shifter you can get the rest of the gears. I don't know much but I would assume it's a bent shift shaft. What could it be and how do I fix it?
Posted March 09, 2015 - 06:49 AM
Sounds like a bent shaft, alright.  Remove the right side crankcase cover and the clutch and it pulls out from that side.  Clean around the seal first.  If it's bent badly, it may give you a problem extracting it as it binds in the cases, and in the case where the binding is excessive, you can cut off either the left end or cut the operating arm off of the shaft on the right side and push it out that way.
  • lferrell22
Posted March 09, 2015 - 08:07 AM
do you think the shaft will be the only thing that needs replaced?
Posted March 09, 2015 - 09:47 AM
That, and the seal, most likely.
  • lferrell22
Posted March 10, 2015 - 04:59 AM
when we pulled the shifter shaft it fought back but it came out and it was badly bent
  • yzdaddy
Posted March 10, 2015 - 06:22 AM
but did you invest in a new chain?
  • lferrell22
Posted March 10, 2015 - 08:14 AM
yeah I got a brand new one
Posted March 10, 2015 - 08:25 AM
Be sure you don't adjust it too tight.  Over tightening the chain is one of the two most common reasons for chain failure, right along with improperly installed master links.  There is also a significant risk of breaking the rear hub with too much tension.
  • x_JT_x
Posted March 10, 2015 - 08:34 AM
I had a friend put a new chain on his bike, and then trade it for something. Guy calls him up couple days later and the chain had come off. He didn't know about master link directions. It's a common mistake. The sad part is that easy mistake can ruin your engine.
  • yzdaddy
Posted March 10, 2015 - 09:00 AM
dont hold back on the money when it comes to chains on a 450
  • Hot  47 replies
  • Hot  36 replies
  • 0 replies
  • On January 15, 2017
  • Hot  28 replies
