2013 WR450: Tight clutch cable in hard left turn
5 replies to this topic
  • mebgardner
Posted March 08, 2015 - 12:04 PM
Any advice about how I could fix a too tight clutch cable, in hard left turn?
It takes all the slack out of the cable, and pulls the clutch "in" slightly, at max left turn.
At straight ahead "neutral", there is about an inch of free play movement at the "mid-lever to handlebar" measurement posiition. That is, it feels like alot of free play...
Thanks.
  • stevethe
Posted March 08, 2015 - 01:18 PM
Hum are you using taller bars. Check your shop manual for cable routing.
  • Krannie McKranface
Posted March 08, 2015 - 04:26 PM
Pull the tank, pull the cable, re route the cable , re install
  • Slow and Jerky
Posted March 09, 2015 - 08:15 AM
I was able to just move the mounting perch in a little to take care of it.
  • mebgardner
Posted March 09, 2015 - 09:15 AM
Yeah, I did forget to mention this: I have a (10mm?) bar riser added, plus a scotts damper with the rubber mounts.
  • mebgardner
Posted March 09, 2015 - 09:17 AM
OK, thanks.  I eyeballed it with no tank removed. I was not sure if I could ignore the OEM routing. I'll try re-routing, and ignore the OEM route.
