My 15 bike
15 replies to this topic
  • Tiago
Posted March 06, 2015 - 04:40 PM
2015 YZ450F Blue version. Mods:
Body
Acerbis Full White Kit
Acerbis Front X-Brake Cover
Acerbis X-Force Handguards
Acerbis X-Seat
Pro-Carbon Tall Frame Guards
Pro-Carbon Exhaust Header Protection (both sides)
Works Connection Skid Plate
Fastway Evo Air Footpegs
Custom Graphics
Performance
Galfer Tsumani Oversize Front Rotor Kit
Magura Clutch Kit
Rekluse Core Exp 3.0
Dr.D Stainless Steel Muffler
Renthal 14-50 spockets
Acerbis chain guide block
Works Connection Axle Blocks
Fasst Company Anti-Vibration Bars Inserts
Progressive Handlebar Dampening System (PHDS)
20mm bar mounts spacers
ODI V2 Lock On Rougue MX Grips
Ride Engineering Fork Compression Adjusters
Works Connection Pro Launch Start Device
Hourmeter with reseat feature for air filter, oil and maintainance
Dr.D Hourmeter bracket
Custom aluminium insert in top clamp nut to screw the hourmeter bracket
Dr.D Radiator Lowering Kit
Factory Effect Radiator Hose White Kit (Y-pipe version)
Pics from todays training
Edited by Tiago, March 06, 2015 - 04:42 PM.
  • dirtbeater
Posted March 06, 2015 - 04:45 PM
Very nice!
  • smv ryder
Posted March 06, 2015 - 05:13 PM
Very nice bike! What's the magura like with the 3.0?
  • Tiago
Posted March 06, 2015 - 11:07 PM
Very nice!
Thanks
It is perfect. The hydraulic pump provides the same lever pull pressure, whether at idle in gear or neutral or above clutch engagement point. Since the magura eliminates the cable play from cold to warm engine, i got the perfect rekluse free play right at the first attempt. Compared with the cable, the magura also provides a smoother lever pull.
I also installed all the blue springs for the lowest rpm engagement that put it pretty close to a stock bike idle. So it kept all the braking engine till the point where a normal bike would stall. You don't notice the difference with the rekluse while riding, just when going into corners you don't have to worry with clutch lever and stay at a higher gear for smoother power delivery into it and more confidence wot while exiting.
Both mods are amazing at its own and kept all its benefits while working together.
Edited by Tiago, March 07, 2015 - 03:17 AM.
  • Tiago
Posted March 06, 2015 - 11:22 PM
Some pics with the original plate number graphics:
  • 250premixer
Posted March 07, 2015 - 10:20 AM
What bar bend is that they look really tall? Maybe because there's no crossbar and hand guards make it look that way.
  • Tiago
Posted March 07, 2015 - 10:40 AM
Stock handlebar. It sits higher due to 20mm bar mounts spacers.
  • Monk
Posted March 07, 2015 - 10:57 AM
What type of suspension setup you running?
  • Tiago
Posted March 07, 2015 - 11:36 AM
With 6ft and 210lbs with gear, i'm liking so far the stock setup. Top fork at 15mm, rebound and compression 8 clicks. Rear is at standard setting.
  • Tiago
Posted March 10, 2015 - 07:38 AM
Custom hourmeter support
Edited by Tiago, March 10, 2015 - 07:39 AM.
  • RMK800
Posted March 10, 2015 - 03:53 PM
Did you lower the rear? Is the forks high in the triple clamps for turning or height?
  • Tiago
Posted March 10, 2015 - 04:48 PM
Like i said before, the rear suspension is at standard setting. At 6' tall i don't feel the need to lower the bike.
The fork height is just to shift bike weight towards the front wheel and improve cornering. My handlebar is just 5mm higher than a stock bike with a flush fork (20mm bar mounts spacers - 15mm forks height = 5mm).
  • Conner_Steezel
Posted March 10, 2015 - 08:49 PM
How do you like the radiator lowering kit? Notice any difference in handling?
  • Tiago
Posted March 11, 2015 - 02:17 AM
Besides the Rekluse, all the mods was made with the bike brand new - 0 hours. I followed all the advices from others experience and bought it because it was pretty easy to install and relative cheap. Imho, i think that the small distance provided from a radiator drop kit or engine relocation towards front is more a placebo thing. I belive that the forks height is alot more noticeable at cornering handling. And what really makes difference is riding style. Every bike is different and you have to adapt your style to take the maximum from the bike, at least at our level. Now if you were within the list of the 25 best riders in the world, then you may notice something.
Edited by Tiago, March 11, 2015 - 02:39 AM.
  • cct
Posted June 28, 2015 - 12:35 AM
I like the Factory Effex Y-hoses, where did you find a new straight pipe to replace the stock metal Y-pipe?
  • Gaz929
Posted June 28, 2015 - 02:11 AM
Where did you get that engine casing from it looks the dogs danglers!
