Need help with my 2014 quick
4 replies to this topic
  • oceantrav
Posted March 06, 2015 - 08:22 AM
Ok, so bought a used 2014 yz450f that had 24 hours, I now have 35 on it.
There was a lot of gunk by the oil strainer. Got new o-rings and finally got around to pulling it out and cleaning it. The first picture shows some kind of lock tite, sealer, gasket, idk. It's a couple small hairs as shown in the picture. what would this be?
Anyways, so I replace the oring with a new one, there's only one right? Then I push the strainer back in the hole, and tighten the 10mm bolt that holds it in place. I tighten the bolt all the way, then check to see how tight the strainer is sitting in there. The stainer is very loose. You can pull it out a tad before it hits the bolt that's holding it In place. This can't be normal, right? What did I do wrong? The second picture is the strainer prior to re installing it.
Edited by oceantrav, March 06, 2015 - 08:23 AM.
  • drtrcr400
Posted March 06, 2015 - 08:25 AM
Normal, as long as it doesn't leak. Your correct, only one o-ring. Also the sealer you see is likely the factory stuff that came off inside the case, looks like the original owner never cleaned the strainer. Enjoy the new ride!
  • oceantrav
Posted March 06, 2015 - 08:46 AM
Ya, the original owner deffinitly never cleaned it. Just seems odd there is so much play in it. Guess I'll ad oil and see what happens.....
  • FRANTIK1
Posted March 16, 2015 - 06:46 PM
The "small hairs" you have is the Yamaha sealer that came from the valve cover gasket, from the half moons. Had the same thing in my strainer from the previous owner. It will fall right down where the timing chain runs. You'll be able to see where it came from when you pull the valve cover for a valve clearance check. At the least you know someone checked the valves.
Edited by FRANTIK1, March 16, 2015 - 06:55 PM.
  • yzUSMCf
Posted March 19, 2015 - 08:00 AM
I wondered the same thing about the movement . It's normal just don't do what I did and tighten the bolt down on the tall plastic peice were you grab it to pull out I cracked mine that way and I replaced it aswell as the new gasket. Looks like yours is cracked might aswell replace it it's cheap.
  • Hot  36 replies
  • 10 replies
  • Hot  38 replies
  • Hot  47 replies
