2003 wr450f headlight problems
5 replies to this topic
  • fasteddie45
Posted March 05, 2015 - 01:05 PM
I have a 03 wr450f and my headlight is super dim when idling (can't even see past front fender) and as soon as i start going the light seems fine for a couple of seconds then the bulb blows i changed the rectifier/ regulator same thing is still happening can someone help me out please
  • thumper_calgary
Posted March 05, 2015 - 02:42 PM
You will need to measure your voltage at the headlight terminal. was it a new or used reg? could be the stator I suppose, are you sure you had the right bulb? the light circut is AC not DC. Not sure if that would make a difference or not....
  • fasteddie45
Posted March 05, 2015 - 03:24 PM
I don't have a service book for the bike and every where i look wont give me an answer for the voltage on the headlight terminal. the rectifier is brand new yamaha oem. And i don't think it's the stator because my battery is holding a charge perfectly fine. And yes i have the right bulb.
  • toten
Posted March 05, 2015 - 07:00 PM
WR450s have two essentially separate electrical circuits. There are two poles off the stator. One of them goes to the regulator/rectifier, producing DC to the battery, starter, and CDI. The other goes to the lighting, and the regulator only side of the r/r. The regulator side is in parallel with the lighting. I'm guessing a bad ground on the r/r could lead to excessive voltage on the AC side.
I managed to find a manual in perfect shape for $11 shipped off ebay. It's for an 04 rather than an 03 but there aren't many differences. I don't see any that cheap right now but keep your eyes open and pick one up when you see one. http://lolinter.net/...r450diagram.pdfis the wiring diagram, http://lolinter.net/wr450/WR450.pdf is a manual but it's trilingual and in my opinion not as good as the paper one. Good luck.
Edited by toten, March 05, 2015 - 07:00 PM.
  • fasteddie45
Posted March 05, 2015 - 08:03 PM
Okay I'll check that out thanks i appreciate the help
  • thumper_calgary
Posted March 05, 2015 - 08:30 PM
13-14v AC at the headlight is what my manual says. Lighting coil resistance should be 0.224-0.336 ohms
