Knobby tires on the road.... Wibble wobble!
50 replies to this topic
  • stevethe
Posted July 31, 2015 - 05:26 PM
#41
Just curious did anyone look for a loose nut connecting the bars to the seat to the foot pegs.
Just an old joke. You know.
Edited by stevethe, July 31, 2015 - 05:26 PM.
  • rah7777777
Posted July 31, 2015 - 07:27 PM
#42
I tried looking but came up empty handed :-)
  • MountAiryTrailRiders
Posted July 31, 2015 - 07:45 PM
#43
I run the same tires on my street legal Ktm 250 xcw 2t (ac10s)there's nothing you can do about that feeling it's just a knobby on the road. Ain't no SM
  • rah7777777
Posted September 08, 2015 - 06:18 PM
#44
Finally installed the GPR V4, which lead to a new top clamp and new hand guards and mirrors and having to build new brackets for my switches (had HDB which all connected together)
Anyhow..... Stabilizer really makes a difference!
Before the GPR, I could barely hit 55 and it would wobble bad. Today I hit 74 before it started feeling bad. But with knobbies on concrete I don't expect it to be perfect.
I did check the steering bearings and they're good. I bought new rims to install as well. Eventually I'll ditch those AC10s and see how it goes from there. But as-is the GPR is a solid investment.
  • bobpara
Posted September 10, 2015 - 05:39 AM
#45
I found my gooseneck bearings were worn and the steering had this 'notchy' feel ....even with a steering stabilizer
When I was riding, esp at low speed, oddly enough it fely like a wobble like I had a bent rim or something
Takes about 5 min to check
Put it up on a stand and turn bars
Should feel perfectly smooth
Also, stand in front of bike
Grab both fork legs at the bottom and pull up and down
  • rah7777777
Posted September 10, 2015 - 04:31 PM
#46
Thanks. She is smooth as can be side to side and no play in steering stem.
Last things to check would be how "true" the rims are.
Maybe balance tires.
From there, get rid of the AC10's.
  • ozijake08
Posted September 11, 2015 - 04:17 AM
#47
dirt bike tires behave like that on tarmac, ride in sand a little and its just as unnerving only 10 fold , just ignor you will get use to feeling
  • rah7777777
Posted September 11, 2015 - 06:44 AM
#48
Honestly I'm pretty good with it now (after installing stabilizer)
I found a good deal on new wheels a bit back that I snagged so I'll install those just to see.
I hate riding in sand... Unless it's just easy paced and open area.
  • dingi
Posted September 11, 2015 - 06:53 AM
#49
D606 rear will feel blocky till you get moving then smothes out. It may take a rwenty minute ride for things to seat right and tread level a bit. Then you are good to go . 20psi serves me good for both on and off since im known to just lock it up and cut right for no apparent reason and go off roading...lol. mt21 front btw. Like no other!
  • Dualsportwr450
Posted September 15, 2015 - 11:53 AM
#50
KENDA Parker dot tires are awesom on dirt and pavement
  • rah7777777
Posted September 15, 2015 - 12:44 PM
#51
I'll look at both of those.
The 11 years I've been riding (street) I've always ran Michelin tires. So when I bought the WR I just stuck with it.
Time to expand my views I guess.
