Need help getting front axle out
7 replies to this topic
  • WilfulLemar20
Posted March 02, 2015 - 12:33 AM
I am fairly new to the yamaha bike and am confused on how to get the axle removed do you have to find an Allen wrench that size to turn the axle out or does the axle just slide out? All advice is apriciated thanks
  • ThumpMe
Posted March 02, 2015 - 09:03 AM
After you loosen the pinch bolts on BOTH sides of the forks it will just slide out. Sometimes I use a soft rubber mallet to get it started.
  • WilfulLemar20
Posted March 02, 2015 - 09:16 AM
Good to hear my right side fork seized on at the moment I put some wd 40 on it waiting to see if that helps any
Posted March 02, 2015 - 09:26 AM
If you want to build a simple but crude tool to use in the socketed end of the axle, pop down to any hardware outlet and pick up a 2 or 3 inch long 1/2 inch USS or SAE bolt and two nuts.  Jam the nuts together on the end of the bolt, the insert either end into the axle.  The 3/4" hex head fits nicely.   That will allow you to spin the axle in the lugs to help free it, to to help with fork alignment on reassembly.
  • Wiz636
Posted March 02, 2015 - 10:23 AM
I have a one of those cheap chainsaw tools for adjusting the bar/chain that fits right in there.
  • WilfulLemar20
Posted March 02, 2015 - 10:40 AM
Thanks for the help guys
Posted March 02, 2015 - 11:38 AM
As does the small end of the OEM tool kit spark plug wrench, if you still have that.
  • WilfulLemar20
Posted March 02, 2015 - 01:52 PM
I finally got it out and wow where the bearings bad ppl need to maintain their bikes better lol now have to take the rim to a buddy's to get a stubborn race out will have new bearings Wednesday come snow or sun I will ride it lol
  • Hot  113 replies
  • Hot  38 replies
  • Hot  36 replies
  • Hot  30 replies
