08 estart problem
2 replies to this topic
  • elnino32
Posted February 26, 2015 - 12:04 PM
I'm confused, bike starts first kick no matter if it's cold or hot, but went I hit the button it just cranks without firing. It's got a new battery that turns nice and fast. I can't figure out what could be different when using the button. Any ideas?
  • Thommo_400f
Posted February 26, 2015 - 12:49 PM
E-Start will never crank as fast as a good kick. Just means your pilot/fuel screw jetting is probably ever so slightly off.
Test by cracking throttle open 1/4 and holding it while you press starter to let a bit more air through.
Then test by turning throttle 3-4 times then pressing starter to pump extra fuel in.
If either helps then you can adjust jetting to suit either add more fuel or lean it out.
I had a similar issue when dialing in my jettting.
  • Krannie McKranface
Posted February 26, 2015 - 01:41 PM
^^^ ditto
fuel screw set properly
hot start maintained and not leaking or stuck
new plug with under 1mm gap
FRESH NEW  pilot jet
