Wiring question - power supply behind light
1 reply to this topic
  • iggs
Posted February 26, 2015 - 08:18 AM
Can anyone give me info on suitable power I can tap into for a trail tech voyager on a 2015 WR450
I haven't got a wiring diagram
I've taken off the oem computer. The power supply for that would probably be ideal.
I can see 4 wires into the plug I think supplied the power. A brown, a white, a red/brown and a green black. Can anyone tell me if these are correct and which to tap into for positive and negative
Thanks in advance.
Ian
Edited by iggs, February 26, 2015 - 09:31 AM.
  • GuyGraham
Posted February 26, 2015 - 10:51 AM
You are looking for a 3 way connector on the harness which is
Red/White is live
Brown is switched live
Black is ground
The other 3 way connector is for the Speedo drive
The four way connector is for the remote handle bar switch (optional accessory from Yamaha)
this applies to a 2008 model
2015 maybe slight diff
Edited by GuyGraham, February 26, 2015 - 10:52 AM.
