help stripped chain adjuster !!
4 replies to this topic
  • yamie_rider
Posted February 08, 2002 - 07:47 PM
My chain adjuster is stripped in my swing arm. Any help
  • Uncle_Rich
Posted February 09, 2002 - 02:23 AM
  • Joel
Posted February 09, 2002 - 10:58 PM
Ok, this might or might not work for you, but usually what happens is the end of the bolt gets rusty, and won't come out. Cut the head off the bolt, cut a slot in it for a screwdriver and just screw it into the swingarm til it falls in and put in a new bolt. Kinda cheesy but it might save you some huge hassles.
  • couly
Posted February 09, 2002 - 11:08 AM
One option would be to get a Heli-coil kit. I use never-sieze on the threads of my adjuster bolts. You can buy it in a small tube now. The heli-coil kit comes with a tap, threaded insert, installation tool. Check to see if it has a drill bit, if it does'nt you'll need the right size.
Good luck,
  • Wyatt
Posted February 10, 2002 - 11:25 AM
I've never seen or used one, but I see this ad alot.
The product is called the swingarm buddy. Hope this helps.
Need help by Goforaride
  • Hot  68 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 5 replies
  • 9 replies
