suspension setup
3 replies to this topic
  • adam080145
Posted February 23, 2015 - 05:35 AM
Hey
I have started to set up my suspension on my wr450 in sm spec. I weigh 220lbs with gear.
I've upgraded the rear spring to a stiffer spring. The front is standard which I know isn't ideal.
Just after advice in clickers top and bottom and rear and front sag.
Cheers
Adam
  • Krannie McKranface
Posted February 23, 2015 - 07:02 AM
It's not just 'not ideal', it's going to be a problem.
All the suspension action will shift to the front, causing loss of control.
You have to do them both at the same time.
Race Sag in the front should be 25-30% of the travel
Static/Race sag in the rear should be 25 / 100-105mm
  • adam080145
Posted February 23, 2015 - 11:12 AM
so when i sit on it it should sag 100-105mm is that for road use with supermoto wheels?
Posted February 23, 2015 - 02:37 PM
Do a google search on 'setting sag'
