Hot Start Plunger
8 replies to this topic
  • WR372
Posted February 10, 2004 - 07:09 PM
The plunger on my 03WR450 has become stripped at the carb. I think I have gotten it tight, but is there a way to check if it is leaking? How hard, what parts do I need to replace/fix this?
Thanks
  • Indy_WR450
Posted February 10, 2004 - 07:33 PM
The hot start plunger is a cheap fix with a new plastic threaded nut assembly you can order from your dealer real cheap. The plastic thread strips very easily! Do not over tighten :)
  • _Blue_Mule_
Posted February 10, 2004 - 07:37 PM
you might try soap and water, put suds around it while running :)
  • oldbones
Posted February 11, 2004 - 02:50 AM
NO! Do not do that! There is not a positive pressure in the carb, it will suck the soap in, not blow bubbles out like a leaky inner tube.
To check for intake leaks, I have heard spray the spot with WD40 or starting fluid and listen for changes in engine RPM.
I just replaced my hot start last night with an solenoid operated, handlebar mounted push-button activated unit. Pretty slick! PM me if you wanna know more.
  • WR372
Posted February 11, 2004 - 09:44 AM
How do you separate the threaded nut from the tube?
  • Indy_WR450
Posted February 11, 2004 - 01:10 PM
Take the cable off and it slides all the way to the other end and off. Put the new one on! :)
  • KiwiThumper
Posted February 12, 2004 - 10:36 AM
I dont know about you guys, but I never, repeat never use my hotstart, never needed to and dont intend to start.
What I am about to embark on is a z-start clutch (thanks and qdos to Desertfoxx for sorting the fedexing !! :) ) but I want to remove the hotstart totally as I will be taking the clutch perch and lever off.
Can I just undo the cable and leave the plunger in? :D
Or is there a better way?
Cheers Deano
  • Indy_WR450
Posted February 12, 2004 - 03:34 PM
No you need to plug the hole with a steel pin and then put the cap on.
  • KiwiThumper
Posted February 12, 2004 - 03:58 PM
OK thanks Indy
