Happy with Applied triple clamp?
10 replies to this topic
  • couly
Posted February 08, 2002 - 01:34 PM
Are you guy's happy with your Applied triple clamps or do you wish you would have bought something else? Applied's sure are alot less money than the others. Some of the others have 3 bolts clamping each tube which must be alot more rigid.
  • SoundChaser
Posted February 08, 2002 - 02:05 PM
I like mine. Im a shorter rider ,5`8", and it opened the cockpit up so I can get a little farther on the tank and have my arms stretched out more. :)
  • motousa
Posted February 08, 2002 - 02:06 PM
Hey there, I have run Applied clamps for 6 years now, and I have always been real happy with them...never had any problems and they look real good. they are noticably more rigid than the stock ones which tend to flex a little. Chances are the clamps you saw that have three bolts were for the lower clamp, not the upper...the applied lowers also have three bolts per fork.
  • DirtJunkiexxx
Posted February 08, 2002 - 02:22 PM
Got a set on order from monkey butt parts.com. I should have them by tues. or wed. of next week!
  • BMC1
Posted February 12, 2002 - 10:39 PM
They're good, put don't plan on the bottom clamps front number plate holes being tall enough to hold the plate in position. Mine pops out all the time.
  • Shawn_Mc
Posted February 13, 2002 - 08:17 AM
I like mine, its clean and easy.
  • Lackey-92
Posted February 13, 2002 - 08:47 AM
I have used them for years on my 400-426s. I bent both the upper and lower (Applied Wraps) last weekend at VP. Although I have never had problems with any previous sets. This set bent and bent very badly. My front wheel was pointing approx. 45 degrees left. No frame or fork damage. The clamps gave up first and I'm happy they did!
  • SealClubber
Posted February 13, 2002 - 09:48 AM
The previous owner was about 5'7. I am 6 feet tall. The bar is too close to me but other than that they seem fine. I am looking to get a new clamp to stretch the cockpit. If you want these, drop me a PM. :)
They are silver.
  • F-Pilot
Posted February 13, 2002 - 03:40 PM
Dan, I am interested in your clamp(s).
Just sent you a pm.
  • F-Pilot
Posted February 14, 2002 - 04:45 PM
Dan, sent you another pm. Reply to my e-mail if possible, it's easier to get to.
Posted February 14, 2002 - 06:43 PM
Love 'em, have them on my 01 CR 125, 01 KTM 200, 01 426 and 02 CR 250. Since I'm 5-8 I like the fit. If I was taller I might turn the bar clamps around and use taller bars!
  • Hot  79 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
  • Hot  36 replies
  • 5 replies
