2010 yz450f not starting
6 replies to this topic
  • jacobYz
Posted February 18, 2015 - 05:04 PM
At first it was dying in first and second with the clutch in. The next day it started and soon died. Now it won't start at all. I cleaned the air filter, and checked the spark plug. None to be the problem so far I was wondering if anyone had this problem with an EFI bike or had any suggestions.
  • billygildark5007
Posted February 19, 2015 - 06:24 PM
There could be several things causing this. Not all efi related.
Did you check your clutch has the correct free play?
Did you check the valves?
Get your hands on a tuner and check for any fault codes.
  • jacobYz
Posted February 19, 2015 - 06:26 PM
Yes about two mins ago I got a fault code 22 which if I'm not mistaken is a coolant sensor failure
  • billygildark5007
Posted February 19, 2015 - 06:37 PM
21 is coolant temp sensor 22 is iat (intake air temp)
It's on the right side of the throttle body above the tps
  • jacobYz
Posted February 19, 2015 - 06:40 PM
Thanks
  • billygildark5007
Posted February 19, 2015 - 07:23 PM
Clean the connection and check the harness and ensure it's plugged all the way in. Clean the little hose and passageway. If that doesn't work replace it.
Posted February 19, 2015 - 08:07 PM
There are specific testing procedures for each sensor in the manual.  Have one?
  • 0 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 5 replies
  • 10 replies
