2012 WR450 and GYTR power tuners question
4 replies to this topic
  • GNTY
Posted February 18, 2015 - 02:11 PM
I've got a 2012 WR450 and am trying to read the engine hours with the GYTR power tuner. Does anyone know if you have to have the competition ECU for the programmer to work? I've done a bunch of searching and seems as though i'm doing everything right. Plug tuner in, turn bike on but not running, tuner powers up automatically but when i go to check monitor the tuner says it cannot connect to ECU.
Any thoughts would be great.
Thanks
Edited by GNTY, February 18, 2015 - 02:12 PM.
  • Krannie McKranface
Posted February 18, 2015 - 03:50 PM
The stock ECU is locked out
Can't do it.
Your odometer has acumulated hours on it.
  • GNTY
Posted February 19, 2015 - 11:20 AM
Can't do it.
Thanks for the reply, thats kinda what I figured. So even if i get the Comp ECU and install that, it probably won't have the total engine run hours on it since new as its a new ECU?
The odometer on the bike has that clock/timer but if i'm correct its resettable? I looked at it this morning and it read 9 hours and im positive the bike has more hours than that on it.
Posted February 19, 2015 - 11:52 AM
Well, I looked it up in the manual, and there is no hour meter
You will have to install your own.
  • GNTY
Posted February 19, 2015 - 12:26 PM
Ya no hour meter in the bikes display, but the beauty of the Power Tuner is that in the Engine monitor function that you can check the engine running time (hour meter) "total time the engine has been running since it was last reset". So if its never been reset it would have the total hours for the bike since new.
