Neutral Switch Question
3 replies to this topic
  • Uncle_Rich
Posted February 08, 2002 - 12:36 PM
Anyone know what the neutral switch does on a 2000 YZ426. I'm gussing either change timing for easier starting or lower rev limiter wile in neutral. I got a ZipTy replacement cover
I've heard of grounding the neutral wire and I've heard of just disconnecting it
What should I do ? HELP
Thanks Rich
  • Teddy_Larsen
Posted February 08, 2002 - 09:18 PM
then is in neutral rev limiter lower rpm.7500
the weather report in Denmark rain rain rain rain rain rain for 8 weks i will by a jet ski
  • PK
Posted February 09, 2002 - 08:54 PM
On 426's (2000-2002) the neutral switch is used to limit engine RPM when in neutral. This is for the Europeans so they can pass the sound check. On 400's it's not used so you can get the bypass and eliminate some wiring. I bought it and it cleaned up the harness a bit.
PK
99 YZ400
  • Uncle_Rich
Posted February 10, 2002 - 10:13 PM
Thanks for the help
Rich
